The risk of exceeding any of the maximum ratings depends on the exact circuit, including bypass capcitors and also the load. I would however use a transistor with a Vds rating above the maximum input voltage, and place a voltage limiting zener diode between gate and source, if the input voltage is above Vgs, max (e.g. 20 V). If the circuit analysis clearly shows, that Vgs can never exceed the maximum rating, you don't need it, of course. But I would prefer, that the circuit is still safe in unexpected situations.
