Simple C codevision question ,, plz help
Terminator Electricity
Member level 5
Member level 5
codevision array
Hi
what does these lines mean ?
what does the following expression mean ?
if(Array & a) ,, while array is a variable hexadecimal value ,, and 'a' is a constant hexadecimal value
and what does this mean ?
a <<= 1;
Thanks ,,
codevision printf
Terminator Electricity said:
if(Array & a)
If the boolean AND of Array and a is non-zero ...
Shift left a by one bit and store result in a.
codevision printf time
Thanks for ur help ,, everything is now clear ,,,,
by the way ,,, do u have an idea how to write an interrupt driven IR RC% code ? cuz i made one with only a timer and it worked perfectly ,, but i have no idea how to start writing the code using interrupt
codevision shift left code
You need a hardware timer for timing the ir pulses, and you must generate interrupts in response to one or both ir pulse edges. The isr should record snapshots of the hardware timer, and then the timer snapshots can be correlated after the ir pulse burst is complete.
codevision printf sample
what do u mean by isr ?
This is my code for IR RC5 reciever using an ATmega16
Chip type           : ATmega16L
Program type        : Application
Clock frequency     : 7.372800 MHz
Memory model        : Small
External SRAM size  : 0
Data Stack size     : 256
void setup_AVR();
#define CHECKBIT(ADDRESS,BIT) (ADDRESS & (1<<BIT))
#include <mega16.h>
#include <stdio.h>
#include <io.h>
unsigned char temp=0;
unsigned char command[10]={0};
unsigned char system[10]={0};
unsigned char timerH=0;
unsigned char timerL=0;
int bitcnt;                     //number of bits waiting to be recieved
unsigned char ref1;                     // 3/4 bit_time
unsigned char ref2;                     // 5/4 bit_time
int i=6;
int j=5;
int k;
interrupt [TIM0_OVF] void timer0_ovf_isr(void)
timerL++;                              //increments every 255* 1/7.372800 seconds
temp++;
if(temp==255) {temp=0;timerH++;} //increments every 255*255* 1/7.372800  seconds
void main(void)
setup_AVR();
#asm("sei")
while (1)
initialize:	temp=0;
		timerH=0;
detect1:	timerL=0;
detect2:	if(timerH>15)	//If no start bit detected within 132ms
                goto fault;
		if(timerL>102)	//If line high for more than 3.5ms
		goto start1;	//then wait for the first start bit
		if(!CHECKBIT(PIND,2))	        //If line is :
		     goto detect1;	// PIND=0  low  - jump to detect1 and reset the timer
		else goto detect2;	// PIND=1  high - jump to detect2 and recheck for 3.5 ms of ideal high
start1:		while(CHECKBIT(PIND,2))//keep checking for the first start bit
                 goto fault;	//then exit    printf("5");
		timerL=0;	//Measure halflength of start bit
start2:		while(!CHECKBIT(PIND,2))//Measure halflength of start bit (low level length)
                if(timerL>26)	//If startbit longer than 1.1ms,
		goto fault ;	//   exit
                //timerL = 1/2 bit time
		ref1 =3.0*timerL/2.0;        //ref1 = 3/4 bit time
		ref2 =5.0*ref1/3.0;        //ref2 = 5/4 bit time
                timerL=0;
start3:		while(CHECKBIT(PIND,2))//check if second starting bit is recieved
                if(timerL>ref1)	//If rising edge is too long
		goto fault;	//exit
		bitcnt  =12;	//Receive 12 bits
                j=5;            //For command
                i=5;            //For system
sample:		timerL  =0 ;
                while(timerL<ref1); // wait untill first 1/4 of next bit
                while(bitcnt>0)
		//Now recieving first 7 bits including the toggle bit
		while(bitcnt>6)
		     { if (PIND.2==0){                             //The bit recieved is 0
		                        system[i]=0;               //store the bit in system
		                        i-- ;bitcnt--;             //prepare for the next bit
		                        while(!CHECKBIT(PIND,2))   //wait untill the next edge
		                          if(timerL>ref2) goto fault;
		                        goto sample;               //wait for the next bit
                       else          {                             //The bit recieved is 1
                                        system[i]=1;               //store the bit in system
                                        while(CHECKBIT(PIND,2))    //wait untill the next edge
                //Now recieving last 6 bits
                if(PIND.2==0){                                     //The bit recieved is 0
                                command[j]=0;                      //store the bit in command
                                j-- ;bitcnt--;                     //prepare for the next bit
                                command[j]=1;                       //store the bit in command
printf("aa");
for(k=5;k>=0;k--)
printf("%d",command[k]);
printf("bb");
for(k=5;k>=0;k--)
printf("%d",system[k]);
fault:		goto initialize;
void setup_AVR()
PORTD=0x00;
DDRD=0x00;
TCCR0=0x01;
TCNT0=0x00;
OCR0=0x00;
TIMSK=0x01;
ACSR=0x80;
SFIOR=0x00;
how do i change it to be interrupt driven ?
codevision shift bit int to char
