SIMCOM300-can't get constant 1 sec led or connect to network
potents
SIMCOM300
I got response of 24,0 on AT+CSQ,
but i am not able to get constant 1 sec led as well as not able to connect to the network,
what could be the problem can anyone suggest.
very urgent please
Re: SIMCOM300
When the module connects to the network the led should blink about once every 3 seconds.
Use the command "AT+CREG?" to get the network registration status. This will tell you if the module is searching, registered, or if registration has been denied. If you have a good signal and cannot register, it may be that no cell is available for your provider (home or roaming), or your SIM card may be invalid. For example, if you are using a 'pre-paid' plan and there is no money in the account your registration will be denied.
