SIM908C GPS+GSM module Help Required
Mithun_K_Das
Advanced Member level 3
Dhaka, Bangladesh, Bangladesh
I've bought a SIM908C GPS+GSM module recently. After some googling I'm confused using this device. As far as I found that this module has pair of Tx & Rx (One for module, One for GPS). This is the main confusion to me. Should I connect these two UARTs or just main Tx,Rx will work?
Purpose of my work with this module is both GSM + GPS. Need help of your experience...
Thank you.
  • SIM908-C.pdf
One Rx-Tx will work some relevant GPS related AT commands are required
like Start GPS engine, Start mode - hot/cold then get the gps location with the preferred mode I think you can easily find in the GPS related AT commands
