SIM900B GPRS LED Indication
lock19
Newbie level 3
Hello Guys,
I am using SIM900B EVB for development purposes. I am able to establish GPRS connection but am not getting any change in the status of the NETLIGHT pin. The LED is supposed to operate at 64ms ON/300ms OFF (indicating GPRS connection is established) but instead it is continuing to operate at 64ms ON/ 3000ms OFF (indicating SIM900B is registered to the network).
Have any of you come across this issue?
Best Regards
What firmware version do you have? My SIM900B EVB is 1137B03SIM900B32_ST and I have the same behavior. I don´t think this is an issue. My advice is to make your own status LED with AT+CIPSTATUS(0x0D).
Best Regards
Reactions: lock19
    lock19
Thank you for your reply.
The firmware version which i am using is 1137B05SIM900B32_ST.
One thing which I would like to mention is that when I used the module as an external modem for my computer and created a dialup connection to GPRS through ATD*99#, the NETLIGHT flashed as expected in the GPRS mode (64ms ON/ 300 ms OFF). But while using CIP commands, the expected behavior is not observed.
Best Regards
