sim900 soldering; How?
abdi110
Member level 3
hello,
Could you please help me how can I solder a sim900 on a PCB?
Do you mean how to build your own SIM900 or do you mean how to connect the SIM900 to a PCB board.
I think he mean to solder the ready-made SIM900 to PCB.
So,it is soldered on component side itself like SMD components. You can solder using SMD soldering. Your PCB pads should be a little longer such that the bottom pads of SIM900 sit on it and also a portion of the PCB pad is available to solder from the outside.
Thank you, Yes I mean to solder the ready made SIM900 to PCB.
I want some help to show me how to solder one sim900 on pcb.
Thanks again,
Does any one have some pic to show how to solder a sim900 module on the pcb?
And what kind of soldering tools should be used?
