sim900 initialization problem
tuan_vu
Newbie level 1
Newbie level 1
Hello,
I am currently working on a project with GSM module SIM900. I connect this module with Altera DE to send command and read data. Everything is quite good, but I still have a problem. After I power up this module, if I use DE board to send the first command to module, there isn't any response for any commands. However, if I use PC to send the first command, the module responses, after that, I connect DE with SIM900 and my code run fluently, I can send commands and read messages. Do you have any idea with my problem? Thank you!!!
I'd verify that the PC (software) isn't sending some initialization sequence to the module, which you probably aren't doing with your Altera design.
