[SOLVED] SIM900 AT Commands : CIPSEND & POP3READ
nimaaa
Newbie level 6
Newbie level 6
Tehran, Iran, Iran
Hi
I'm Starting to Work with Sim900 and I have two problems
I'm going to command the sim900 via an avr microcontroller and get data from sim900
1. in the manual it is written that after using the POP3READ AT Command , the data is read completely and it's ready
my problem is that how to see and use this data from USART ?
Is there any At Command to be used to get the data ?
2. In the maunal it is written that :
AT+SMTPBODY=response">" then type data as body , tap CTRL+Z to save , tap ESC to cancel the operation
(same for CIPSEND)
I've got confused with 'CTRL+Z & ESC ' :-(
I can't figure out how to use them.Because I'm not going to use keyboard. would you explain it a bit to me ?
Thank YOU
@Nimaa,
For the query 1: The data will be in the USART...Its just you need to get the data from the USART buffer...As once the command POP3READ is issued, the data is pushed to the USART...and will be stored in the USART buffer.
For the query 2:
1. CTRL+Z ---> 0x1A
2. ESC ----> 0X1B
You have to send the hex value from the AVR controller to the SIM900A module...Look into the ASCII table...
Reactions: nimaaa
    nimaaa
thank you kgshankar
I was considering that the response of POP3READ is just "OK"
So I should save it in a secondary character before getting the "OK" if it is available in the USART buffer , as you said .
and also thanks for your help about the query 2 . I will work on it
Best Wishes
