I need your help please.
Which one is better between sim300c and cinterion mc55i. I have no experience with both of modules.
What I want are stability, less of bug and easy to use. I want to use it in datalogger with GPRS data transfer.
Hi andrea. The sim300 is easer to use if you compare with MC55i, but the Cinterion module is more stable and secure. In fact to use with a data logger is very hard for both, because you´ll need a controller to do a interface between the modules and datalogger. I recommends you to use the rs232 port in this case, it will be easier than usb port. Depends on the sistem, you can´t use USB port at all.
:arrow: Many companies i know have been using MC55i (Quad band) in datalogger for transfer of data through GPRS, & its more than successful. feedbacks from customers for MC55i is very Stable, Reliable & good product compared to SIM 300 modules.
however sim 300 modules are less costly... its your choice to go for..:-|
