sim300 pic
Hi All,
I'm interfacing the Sim300 with a PIC Microcontroller. The PIC works with 3,3V High Output Level and the Sim300 works with 2,051V to 3,23V as High Input voltage.
Acording to the Sim300 Datasheet:
(Logic high input Min: 0.7 *VDD_EXT = 2,051V)
(Logic high input Max: VDD_EXT +0.3V = 3,23V)
Which is the best way to balance the PIC output level with the Sim300 Input Level?
At the moment i'm using a 2.4V Zener Diode direct in the PIC pin, but one can use a transistor driver.
How do you make this is your project?
