user0n9
I bought few pieces of SIM300 recently..
after i attached the SIM300 to a self design board and without switching on the SIM300,
the drain current of the board is 16mA
after switch on SIM300 in full functionality mode (CFUN=1) the Drain current is around 23.86mA
when in minimum functionality mode (CFUN=0) the Drain current is consider fixed at 23.86mA
when no RF circuit mode (CFUN=4) the Drain current is consider fixed at 23.92mA
and in sleep mode the Drain current is 18.45mA
so we can see that sleep mode takes around 2.45mA which is correct and almost same as stated in Manual
but why CFUN 0, 1, 4 drain current does not have not much different?
as what i read.. CFUN 0 should have the lowest current consumption compare to CFUN 2 and CFUN 4.
can you help me with this please?
p/s: the board is functioning as expected (no problem at all for voice call, sms, gprs and so on)
thanks in advance
Pierre
thanks in advance
Pierre
