OmarKhan
Newbie level 1
Hi
I am developing a tracking system using your SIM908 modules. Previously we have used the SIM508 and SIm548C modules. The problem i'm facing is that when i send the "AT+CGPSSTATUS?" command via the serial port, i get the response "+CGPSSTATUS: Location Unknown" and "AT+CGPSINF=0" gives message "0,0.000000,0.000000,0.000000,20101010000641.000,0,2,0.000000,0.000000 OK". The debug/GPS port of the module (pin 15,16) give a continuous High value no NMEA info even though i have sent the "AT+CGPSOUT=255" AT command. My firmware revision number is "Revision:1137B01SIM908M64_ST_DTMF_JD_EAT". I have connected the GPS_VANT_IN to 4.0 volts as i'm using an active antenna with a 3-5 volts range. The GPS_VANT_Out pin is unconnected. Please help me in resolving this issue, as it is very important for us.
Awaiting your prompt reply.
Omar Khan
Please also suggest the most suitable GSM and Active GPS antenna for SIM908 Module.
Omar Khan
