SIM 300 V7.03 Under Voltage Warning
anil404
Hi all,
i have a sim300 gsm module , when i give commands its giving UNDER VOLTAGE WARNING . what is the reason to get this warning . How to resolve it. The modem is using 7805 regulator is it k ot shall i replace with LM317.
i found the reason is due to low volatge at VBAT<3.5.
How to resolve it.
Boost voltage to needed voltage, or use adequate power source.
You probably try with Li-Ion battery, and voltage falldown under load.
To use 7805 at least 2,5V-3V difference is needed between input and output voltages.
thank you for your reply tpetar,
I am also having problem with sim900A. The modem is continuously restarting after registration.
What may be the problem ?
when i run the batch file "run"...then mode sets to read(at+cmgr=1) and its starts to read the first message continuously...can any1 please help me out of this??
thanks!!!
thanks!!!
As per i know In at+cmgr=1 , 1 indicates message number . So it reads msg 1 continuously.
yeah....it's happening like that only...but if i send messages it's not responding...is there any possibilities to reset it?
