silk screen printing help
Full Member level 4
egypt
hiiiii :grin:
can i print smd tqfp 144pin by silkscreen.
pranam77
Advanced Member level 5
INDIA
Depends on which screen are you using. TQFP of 144 will have very low distances between pins and this the screen need to be of high density. Usually negetive film method best suits for SMD devices.
Cheers
5282604
Full Member level 4
egypt
Cheers
thank you very much.
i use transparent paper
what is best kind of laser printer to print on it. i use hp1005 laser jet but it printing quality on transparent paper very poor.
tpetar
Pancevo-Belgrade, Serbia
Use HP LaserJet 1200 (new generation) 1200x1200dpi and high density toner, printing is better then original. :wink:
pranam77
INDIA
thank you very much. i use transparent paper
If you are using just a transparent paper, the printing resolution is sure to be affected coz the laser printer just cannot print on any transparencies. There are certain transparent sheets which are meant for inkjet and laser printing whcih are slightly rough on one side. You may use those if available or for ease use a butter sheet used for regular screen printing stensils. But warming the paper under a 60 watt bulb before printing will give better results.
