I found vhdl use signal and verilog use wire and reg to describe a connection between combinational logic, but the thing bothered me that "how to specify the signal to be wire or reg" or " signal equal to wire or reg" ? :roll:
davyzhu..
I guess u r trying to convert some VHDL to verilog. Well a signal in VHDL can be reg or wire in verilog.. ie if the signal is intended to be synthesised as a flop .. it shud be reg... else wire...
Inside the "process" statement , if any signal is assigned to any other signal it will be flop .. or if outside process it will be a net..
davyzhu..
In Verilog, 'reg' does not have to be synthesised as flop or latch, even when it's in the 'always' statement. Also, I wondered if 'signal' in the 'process' in VHDL was always synthesised into flop or latch? As I just started to use VHDL, will any VHDL guru clarify this point? cheers
I believe that there is no straight forward relation however, I yoou can use this rule, if the signal is synthesized as a register or latch, then use reg otherwise use wire, I believe it is this simple.
However Iwant to note that not all process in VHDL produce a reg. or latch but it depends on two things, 1- the sensitivity list, 2- wether all conditions of changes were included in the process code area.
