chaudhurysid
Newbie level 2
I want to transmit a signal over seven fibre optic cables simultaneously. The input will be from a copper cable, input voltage 24V. Can anyone suggest a device/method to do this which can help me do this.
if the signal is less than 24V then there is a need of resistor is required or not and if not then what will be its effect over the LED ... help..
