Sign extension problem. Msb doesn't copy properly with a loop.
sarjumaharaj
Junior Member level 1
Hello,
I am making mips processor and I had to make a component which would make 16 bit vector into 32 bit vector. I used a simple for loop to copy the msb of the 16 bit vector to the rest of the 16 bits of the 32 bits vector. (see the code). However the output is so haywire. Sometimes it gives 0 when MSB is 1 and sometimes 0 when MSB is 1. Can someone please please please see the code and see what is wrong with my code.
Also, I heard there is a function called sxt to sign extend a logic vector. I tried that but VHDL doesn't identify the sxt. Do we require any library for sxt function. If so which one.
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity sign_extend is
	port ( offset : in std_logic_vector ( 15 downto 0 ) ;
			 offset_out : out std_logic_vector ( 31 downto 0 )  ;
			 msb_check : out std_logic
end sign_extend;
architecture Behavioral of sign_extend is
	signal msb : std_logic;
	signal temp: std_logic_vector ( 31 downto 0 ):= (others => '0') ;
begin
	process (offset)
	begin
		msb <= offset (15);
		temp ( 15 downto 0 ) <= offset ;
		for i in 16 to 31  loop
			temp (i) <= msb ;
		end loop;
	end process ;
	msb_check <= msb ;
	offset_out <= temp ;
end Behavioral;
TEST BENCH :
-- Company:
-- Engineer:
-- Create Date:   12:40:11 04/29/2014
-- Design Name:
-- Module Name:   C:/Users/WORK/Desktop/MIPS PROCESSOR/COMPONENTS/sign_extend/tb.vhd
-- Project Name:  sign_extend
-- Target Device:
-- Tool versions:
-- Description:
-- VHDL Test Bench Created by ISE for module: sign_extend
-- Dependencies:
-- Revision:
-- Revision 0.01 - File Created
-- Additional Comments:
-- Notes:
-- This testbench has been automatically generated using types std_logic and
-- std_logic_vector for the ports of the unit under test.  Xilinx recommends
-- that these types always be used for the top-level I/O of a design in order
-- to guarantee that the testbench will bind correctly to the post-implementation
-- simulation model.
LIBRARY ieee;
USE ieee.std_logic_1164.ALL;
-- Uncomment the following library declaration if using
-- arithmetic functions with Signed or Unsigned values
--USE ieee.numeric_std.ALL;
ENTITY tb IS
END tb;
ARCHITECTURE behavior OF tb IS
    -- Component Declaration for the Unit Under Test (UUT)
    COMPONENT sign_extend
    PORT(
         offset : IN  std_logic_vector(15 downto 0);
         offset_out : OUT  std_logic_vector(31 downto 0);
         msb_check : OUT  std_logic
    END COMPONENT;
   --Inputs
   signal offset : std_logic_vector(15 downto 0) := (others => '0');
 	--Outputs
   signal offset_out : std_logic_vector(31 downto 0);
   signal msb_check : std_logic;
   -- No clocks detected in port list. Replace <clock> below with
   -- appropriate port name
--   constant <clock>_period : time := 10 ns;
BEGIN
	-- Instantiate the Unit Under Test (UUT)
   uut: sign_extend PORT MAP (
          offset => offset,
          offset_out => offset_out,
          msb_check => msb_check
   -- Clock process definitions
--   <clock>_process :process
--   begin
--		<clock> <= '0';
--		wait for <clock>_period/2;
--		<clock> <= '1';
--   end process;
   -- Stimulus process
   stim_proc: process
   begin
      -- hold reset state for 100 ns.
      wait for 100 ns;
		offset <= "1101010101010101" ;
		wait for 100 ns ;
		offset <= "1100000000000000" ;
		wait for 100 ns ;
		offset <= "1111000000111100" ;
		wait for 100 ns;
		offset <= "1111111111111111" ;
		wait for 100 ns ;
		offset <= "1011111100011110";
--      wait for <clock>_period*10;
      -- insert stimulus here
      wait;
   end process;
END;
