Mar 26, 2021 #1 M muhammad11 Member level 2 Joined Nov 1, 2013 Messages 43 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,572 What is function of SIC rectifier in modulator stage of transmitter, Kindly explain the working of SIC rectifier.
Mar 26, 2021 #2 danadakk Advanced Member level 6 Joined Mar 26, 2018 Messages 3,182 Helped 417 Reputation 855 Reaction score 745 Trophy points 113 Activity points 13,726 Superior V drop for starters = low loss = low heat = smaller size = higher efficiency = fast recovery..... SiC Diodes - STMicroelectronics ST’s silicon carbide diodes range from 600 to 1200 V – as single and dual diodes – and feature unbeatable reverse recovery characteristics and improved VF. www.st.com AM ? https://www.tutorialspoint.com/analog_communication/analog_communication_am_modulators.htm Regards, Dana.
Mar 28, 2021 #3 M muhammad11 Member level 2 Joined Nov 1, 2013 Messages 43 Helped 0 Reputation 0 Reaction score 0 Trophy points 1,286 Activity points 1,572 Sic diode has same polarity as that of ordinary diode(attached here) or it has opposite polarity ? Kindly explain Attachments diode.png 2.6 KB · Views: 82
Mar 28, 2021 #4 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,513 Helped 14,759 Reputation 29,800 Reaction score 14,128 Trophy points 1,393 Location Bochum, Germany Activity points 298,483 If the case has a marking bar, you can be pretty sure that it's indicating the cathode terminal. If not, review the datasheet.
