Sceadwian
Full Member level 3
Can someone supply me with more information/thoughts on shunt resistors and measuring current draw from a device? I'd like to be able to read the voltage created from the shunt resistors on an industrial rectifier at work (I don't have the stats on it yet though) I'd also like to measure milli/micro amps from some general I/O pins. I know so little about shunts (including creating them) I'd like to use CAT5 cable to create some test shunts, but I lost the link to the page that had a calculator to figure out how long the cable needed to be to get a certin ohmic value. I only want to test basically from 0 to 1 amp. Using my micros (AVR) that'll give me .003ma resolution which sounds like a good test to me. I worked out for my first test I need a .128 ohm resistor. I don't have anything floating around I can really use for that accept for CAT5 cable. For refrence the ADC I'm using is differential 0-2.56 with a 20X gain stage so really 0-.128 volts 8bits so it can measure(reliably) about 1mv differences.
