vinay shabad
Junior Member level 3
hiiii i am getting error as undeclared sspcon
* Hardware I2C single master routines
* (adapted from application note AN235)
* i2c_init - initialize I2C
* i2c_start - issue Start condition
* i2c_repStart - issue Repeated Start condition
* i2c_write - write char - returns ACK
* i2c_read(x) - receive char - x=0, Issue a don't acknowledge (NACK)- x=1, Issue an acknowledge (ACK)
* i2c_stop - issue Stop condition
#include <P24F16KA102.h>
#include "i2c.h"
//#include "Compiler.h"
void i2c_init(void) {
TRISBbits.TRISB5 = 1; // Digital Output (make it input only when reading data. see spi)
// PORTBbits.RB5 = 1;
TRISBbits.TRISB6 = 1; // Digital Output
// PORTBbits.RB6 = 1;
SSPCON1 = 0x28; // enable I2C Master mode
SSPCON2 = 0x00; // clear control bits
SSPSTAT = 0x80; // disable slew rate control; disable SMBus
SSPADD = 19; // set baud rate to 100 kHz (Fosc = 48 MHz)
PIR1bits.SSPIF = 0;
PIR2bits.BCLIF = 0;
void i2c_start(void) {
PIR1bits.SSPIF = 0; //clear flag
while (SSPSTATbits.BF ); // wait for idle condition
SSPCON2bits.SEN = 1; // initiate START conditon
while (!PIR1bits.SSPIF) ; // wait for a flag to be set
PIR1bits.SSPIF = 0; // clear flag
unsigned char i2c_write( unsigned char i2cWriteData ) {
PIR1bits.SSPIF = 0; // clear interrupt
while ( SSPSTATbits.BF ) ; // wait for idle condition
SSPBUF = i2cWriteData; // Load SSPBUF with i2cWriteData (the value to be transmitted)
return ( !SSPCON2bits.ACKSTAT ); // function returns '1' if transmission is acknowledged
unsigned char i2c_read( unsigned char ack ) {
unsigned char i2cReadData;
SSPCON2bits.RCEN = 1; // enable receive mode
i2cReadData = SSPBUF; // Read SSPBUF and put it in i2cReadData
if ( ack ) { // if ack=1
SSPCON2bits.ACKDT = 0; // then transmit an Acknowledge
} else {
SSPCON2bits.ACKDT = 1; // otherwise transmit a Not Acknowledge
SSPCON2bits.ACKEN = 1; // send acknowledge sequence
return( i2cReadData ); // return the value read from SSPBUF
void i2c_stop(void) {
SSPCON2bits.PEN = 1; // Initiate STOP condition
void i2c_repStart(void) {
SSPCON2bits.RSEN = 1; // initiate Repeated START condition
error ****************************************
\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c: In function 'i2c_init':
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:28: error: 'SSPCON1' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:28: error: (Each undeclared identifier is reported only once
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:28: error: for each function it appears in.)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:29: error: 'SSPCON2' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:30: error: 'SSPSTAT' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:32: error: 'SSPADD' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:34: error: 'PIR1bits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:35: error: 'PIR2bits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c: In function 'i2c_start':
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:43: error: 'PIR1bits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:44: error: 'SSPSTATbits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:46: error: 'SSPCON2bits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c: In function 'i2c_write':
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:56: error: 'PIR1bits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:57: error: 'SSPSTATbits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:59: error: 'SSPBUF' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:64: error: 'SSPCON2bits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:66: warning: control reaches end of non-void function
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c: In function 'i2c_read':
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:74: error: 'PIR1bits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:76: error: 'SSPSTATbits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:77: error: 'SSPCON2bits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:82: error: 'SSPBUF' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c: In function 'i2c_stop':
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:103: error: 'PIR1bits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:104: error: 'SSPSTATbits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:106: error: 'SSPCON2bits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c: In function 'i2c_repStart':
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:117: error: 'PIR1bits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:118: error: 'SSPSTATbits' undeclared (first use in this function)
C:\Program Files\Microchip\mplabc30\v3.25\support\peripheral_24F\i2c.c:120: error: 'SSPCON2bits' undeclared (first use in this function)
i am blocked here can some one please helpme
thanku in advanced
#include "i2c.h"
PIR1bits.SSPIF = 0;
PIR2bits.BCLIF = 0;
} else {
thanku in advanced
