Mithun_K_Das
Advanced Member level 3
- Joined
- Apr 24, 2010
- Messages
- 899
- Helped
- 24
- Reputation
- 48
- Reaction score
- 26
- Trophy points
- 1,318
- Location
- Dhaka, Bangladesh, Bangladesh
- Activity points
- 8,254
I was working with some power unit. Usually I use micro-controller in this case. But I don't want to use MCU for this small circuit. So I designed one and its working well.
But the problem is if it once shorted, loads off. and never turns on the load until load terminal is opened. That means, once I short the terminals while the lamp was on, the circuit turns the light off. and can't turn it on until the load(lamp) is removed/open from the terminal.
What I was expecting, the circuit will auto reset the protection. But there should not be any complexity.
I want to fit the whole protecting circuit inside a 10mm dia tube. Is there any modification you can provide?
