albus
Junior Member level 2
I'm a little bit confused with grounding a high voltage source. In the above image I don't understand exactly why the person is not electrocuted. Why electrons doesn't flow from the negative end of the source to the ground? Do electrons always have to flow from the negative end to the positive end of the source to complete the path?
