7mod998
shift register , i have troubles when creating components please help!
mux code
clk div code
shift reg code
final design
mux code
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 library IEEE; use IEEE.STD_LOGIC_1164.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity mux is Port ( A0,A1,A2,A3,S0,S1 : in STD_LOGIC; IL : out STD_LOGIC); end mux; architecture Behavioral of mux is signal s: std_logic_vector (1 downto 0 ); begin S <= S1&S0; with S select IL <= A0 when "00", A1 when "01", A2 when "10", A3 when "11", '0' when others; end Behavioral;
clk div code
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 library IEEE; use IEEE.STD_LOGIC_1164.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; entity clk_div is Port ( clk : in std_logic; clk2: out std_logic ); end clk_div; architecture Behavioral of clk_div is begin process(clk) variable c : integer range 0 to 50000000:=0; begin if(clk'event and clk='1')then c:=c+1; if(c=50000000) then c:=0; clk2<='0'; elsif (c=25000000) then clk2<='1'; elsif(c<25000000) then clk2<='0'; end if; end if; end process; end Behavioral;
shift reg code
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 library IEEE; use IEEE.STD_LOGIC_1164.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; ENTITY shifter_unit is PORT(clk, il, ir,sin : in std_logic; s: in std_logic_vector (1 DOWNTO 0); i : in std_logic_vector (3 DOWNTO 0); q : out std_logic_vector (3 DOWNTO 0)); END shifter_unit; ARCHITECTURE Behavioral of shifter_unit is SIGNAL qtmp : std_logic_vector(3 DOWNTO 0); BEGIN q<=qtmp; PROCESS(clk) BEGIN IF (clk = '1' AND clk'EVENT) THEN CASE s IS WHEN "00" => qtmp <= i; WHEN "01" => qtmp<=sin&qtmp(3 downto 1); WHEN "10" => qtmp<=qtmp(2 downto 0)&sin; WHEN "11" => qtmp<=qtmp; WHEN OTHERS => NULL; END CASE; END IF; END PROCESS; q <= qtmp; end Behavioral;
final design
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 library IEEE; use IEEE.STD_LOGIC_1164.ALL; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values --use IEEE.NUMERIC_STD.ALL; -- Uncomment the following library declaration if instantiating -- any Xilinx primitives in this code. --library UNISIM; --use UNISIM.VComponents.all; ENTITY final_design is PORT(clk, c : in std_logic; s: in std_logic_vector ( 3 DOWNTO 0); A : in std_logic_vector (3 DOWNTO 0); q : out std_logic_vector (3 DOWNTO 0)); END final_design; architecture Behavioral of final_design is component mux is Port ( A0,A1,A2,A3,S0,S1 : in STD_LOGIC; IL : out STD_LOGIC); end component; component shifter_unit is PORT(clk, il, ir,sin : in std_logic; s: in std_logic_vector (1 DOWNTO 0); i : in std_logic_vector (3 DOWNTO 0); q : out std_logic_vector (3 DOWNTO 0)); END component; component clk_div is Port ( clk : in std_logic; clk2: out std_logic ); end component; signal il, ir, clk1 : std_logic; begin uo:mux port map (S(1),S(0),A(0),c,'0',A(3),il); u1:mux port map (S(1),S(0),A(0),c,'0',A(3),ir); u2:shifter_unit port map (clk1,il,ir,S(3 downto 2),A(3 downto 0),q(3 downto 0)); u3:clk_div port map(clk,clk1); end Behavioral;
