I'm new to ATPG simulation debug. I heard from my colleague saying there is some kind of shadow path, because of that parallel simulation is failing but serial is passing. Can anyone please give me an idea of what is shadow path and how it will effect the parallel simulation.
A shadow flop is a non-scan flop that has the D input
connected to the Q output of a scan flop. Under certain circumstances, such shadow cells are
not loaded correctly in the parallel testbench
Such cells do not cause DRC violations, but the
tool issues the following message when going into atpg mode : // 1 external shadows that use
shift clocking have been identified
If you see this message , it indicates that you have SHADOW cells in your design and that the mismatch that has been reported might be due to this problem
