ajitnayak
Junior Member level 2
Dear all,
Initially i coded for single axis solar tracker.The code working fine for Single axis system. Now I have array of solar tracker They are place 3200mm apart from each other.Now i wanted implement back track algorithm here. My location latitude:13.08 longitude:80.20.
Back track algorithm here is adjust panel such way that max shadowing get avoided.
x- modules length=1700mm
ω-modules angle will changes with time, Since i am using linear actuator my actuator angle will be +45 from 7AM to 9:30 Am and -45 from 3.30 pm to 18pm. During this period my tracker position will be in +45 or -45 deg angle. So question here during this period how to adjust panel posttion inorder to avoid shadow
Shadow length calculation formula
http://www.mysolarpannels.com/optimum-angle-for-solar-panels/
Excel fine found in below link.
http://www.google.co.in/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CDQQFjAB&url=http%3A%2F%2Fwww.esrl.noaa.gov%2Fgmd%2Fgrad%2Fsolcalc%2FNOAA_Solar_Calculations_day.xls&ei=eFY5U7O6NYaYrAeClIGYDA&usg=AFQjCNH6LEYbHQ1tFb6OIOSyub6lzAaesw&bvm=bv.63808443,d.bmk
