Sg3525 feedback problem
hamid159
Full Member level 3
Full Member level 3
Lahore
Hi guyz,
i'm having problem related to sg3525 feedback.i've made a circuit but don't know how i can implement the feedback circuit.please help me.output voltage is about 24V.
  • UC2525IC.PDF
You have made a Half bridge circuit.
Please try this link for feed back circuit design, It is for push pull converter but logic is same.You have to redesign the voltage divider.
Thanks smijesh,
what is the purpose of resistors and capacitors at pin 1 of sg3525.how it works.i've used this type of feedback but except resistors and capacitors at pin 1.but output voltages is not regulated.At 5amperes load,output voltage drops by 2.5V and at 8 amperes,it drops by 4.7V.is this a normal case or I can make it better by proper feedback?Please help me guyzz.here is schematic
  • sg3525 tl431 feedback.pdf
The theory behind the feed back : A voltage comparator having inverting terminal and non inverting terminal. You have to set a reference voltage to non inverting terminal say 2.6V (5.5 Reff of sg2525 / 2). Then you give 2.6V to inverting terminal from output through opto isolator. If any change from output will change the PWM duty cycle of PWM. Capacitor is using for filtering the spike in the voltage.
