Feb 16, 2012 #1 F fanwel Full Member level 3 Joined May 26, 2011 Messages 178 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 2,878 Hi all; I want to convert sfixed number to std_logic_vector in vhdl. I use to_slv function as in the code below: library ieee; library ieee_proposed; use ieee_proposed.fixed_pkg.all; use ieee.std_logic_1164.all; entity fix is port (clk: in bit; nprev: in sfixed (3 downto -4); op1: out std_logic_vector(7 downto 0)); end fix; architecture fix of fix is signal n1: std_logic_vector(7 downto 0); begin process(clk) begin if (clk'event and clk='1') then op1 <= to_slv(nprev,n1); end if; end process; end fix; But an error said: Error (10476): VHDL error at fix.vhd(19): type of identifier "nprev" does not agree with its usage as "UNRESOLVED_ufixed" type. Is it I use the to_slv function in the right way? What my mistake? Need helps..Thank you
Feb 16, 2012 #2 FvM Super Moderator Staff member Joined Jan 22, 2008 Messages 52,411 Helped 14,749 Reputation 29,780 Reaction score 14,096 Trophy points 1,393 Location Bochum, Germany Activity points 298,058 Doesn't a simple type case work? Code: op1 <= std_logic_vector(nprev); P.S.: fixed package to_slv() doesn't have a length parameter, I think Last edited: Feb 16, 2012
Feb 16, 2012 #3 F fanwel Full Member level 3 Joined May 26, 2011 Messages 178 Helped 2 Reputation 4 Reaction score 2 Trophy points 1,298 Activity points 2,878 FvM said: Doesn't a simple type case work? Code: op1 <= std_logic_vector(nprev); P.S.: fixed package to_slv() doesn't have a length parameter, I think Click to expand... Yes, you're right..Thanks for helping
