hi i need some help regarding finding the settling time of a fully differential op amp...
i am working on fully differential op amp for the first time.....
1. plz explain me how to connect the op amp as a buffer for testing the settling time( i mean should i have to connect any capacitors or resistors between the inputs and outputs or between the inputs) ?:roll:
2. the input step should be applied to one input and the output should be measured at the output which is connected to other input or any other method?
i will be grateful if anyone can explain the procedure in a detailed manner with images?....
thanks in advance......
