What is .5 resistor?Tim2255 said:OK I put a .5 Risistor
That's rather obvious ..Tim2255 said:Is that because the lights are 3.6V and I am only running 3V with the C-batteries?
One more will be enough ..Tim2255 said:Should I get two more C batteries and then attach a resisitor? If so what size resisitor would I need? Thanks in advance.
That sounds good ..Tim2255 said:1. With a three prong toggle switch should I have wired one hot from the battery to one prong, the hot to the led lights to another prong and then all the negatives to the ground?
No, it's not, looks like the switch shortens the battery through resistor ..Tim2255 said:2. As I stated, i think I have everything set up where it works now, but I notice my resisotr gets very hot when the lights are out, is this normal?
