Set_multicycle path regarding
vimalraj205
Member level 3
Member level 3
Hai friends
i have doubt whether can i set a multicycle path of setup value 0
set_multicycle_path -setup 0 -from xxx -to yyyy -end
will i be able to meet setup and hold for this path if setup is checked at 0 how should i give a multicycle path for a hold check
Thank you
I think it's unable to meet both setup and hold for such, if you using usual library cells. And it's also un-reasonable for the real DFF to have setup and hold both equal to 0.
In gerneral,the cycle of setup check is less one than hold check.so the constraint for this path should be set_multicycle_path -hold -1 -from xxx -to yyyy
