Feb 16, 2005 #1 N no_mad Full Member level 5 Joined Dec 10, 2004 Messages 271 Helped 30 Reputation 60 Reaction score 11 Trophy points 1,298 Location Naboo Activity points 2,489 set_case_analysis Hi all, My design has inputs from a register. Meaning, these inputs always fix either at 0 or 1. To synthesize this design, can I set these inputs port with “case_analysis” or is it better to set it as false_path?? Please enlighten me.. -no_mad
Feb 17, 2005 #2 H horzonbluz Full Member level 4 Joined May 1, 2002 Messages 208 Helped 11 Reputation 22 Reaction score 9 Trophy points 1,298 Activity points 1,530 set_case_analysis input Yes, you can use the command to set these input signals.
Feb 17, 2005 #3 T tony_taoyh Full Member level 2 Joined Oct 20, 2004 Messages 131 Helped 6 Reputation 12 Reaction score 3 Trophy points 1,298 Activity points 1,785 set_case_analysis is not working I think it is better not to "set_case_analysis"... set_case_analysis is mostly used for those control pins like, scan enable... These controls pin will modify the mode of the chip's operation, suck as clock distribution, like scan mode. If it is not, do not use set_case_analysis... then DC may consider the timing check more completely...
Feb 17, 2005 #4 N no_mad Full Member level 5 Joined Dec 10, 2004 Messages 271 Helped 30 Reputation 60 Reaction score 11 Trophy points 1,298 Location Naboo Activity points 2,489 set case_analysis hi Tony, So, it is better to use set_false_path unless I want to do a scan chain..
