Servomotor. PWM and VHDL
Gilgamesh90
Newbie level 2
Newbie level 2
Hi:
I'm trying to control a servomotor HS-645MG with the Altera FPGA DE0 using VHDL. According to my limited knowledge (and according to other programmers) these are the code for frequency dividing and pwm:
Frequency divider:
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
entity clk64kHz is
    Port (
        clk    : in  STD_LOGIC;
        reset  : in  STD_LOGIC;
        clk_out: out STD_LOGIC
end clk64kHz;
architecture Behavioral of clk64kHz is
    signal temporal: STD_LOGIC;
    signal counter : integer range 0 to 4999 := 0;
begin
    freq_divider: process (reset, clk) begin
        if (reset = '1') then
            temporal <= '0';
            counter  <= 0;
        elsif rising_edge(clk) then
            if (counter = 4999) then
                temporal <= NOT(temporal);
                counter  <= 0;
            else
                counter <= counter + 1;
            end if;
        end if;
    end process;
    clk_out <= temporal;
end Behavioral;
PWM
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.STD_LOGIC_unsigned.all;
entity pwm is
	port(
		clr : in std_logic;
		clk : in std_logic;
		duty : in std_logic_vector (7 downto 0);
		period : in std_logic_vector (7 downto 0);
		pwm : out std_logic
end pwm;
architecture pwm of pwm is
signal count : std_logic_vector(7 downto 0);
begin
	cnt: process(clk, clr) -- 4 bit counter
	begin
		if clr = '1' then
			count <= "00000000";
		elsif clk'event and clk = '1' then
			if count = period -1 then
			else
				count <= count +1;
			end if;
		end if;
	end process cnt;
	pwmout: process(count, duty)
	begin
		if count < duty then
			pwm <= '1';
		else
			pwm <= '0';
		end if;
	end process pwmout;
end pwm;
Top-design code
library IEEE;
entity pwm_top is
	port(
		clr : in std_logic;
		clk : in std_logic;
		pwm : out std_logic
end pwm_top;
architecture pwm_top of pwm_top is
signal new_clock : std_logic;
begin
clk_div: entity work.clk64kHz
		port map(
			clk => clk, reset => '0', clk_out => new_clock);
Pulse: entity work.pwm
		port map(
			clr => clr, clk => new_clock, duty => duty, period => "11001000", pwm => pwm);
end pwm_top;
Described with my own words, the frequency is divided by a 5000 factor which yields to a new frequency of 10000Hz (0.1ms). Then the period of the pwm is assigned as 200 so the frequency of pwm will be 20ms and the duty cycle will be controlled with the DE0 built-in switches.
Unfortunately this doesnt work very well when the servo is connected, for example, if the duty cycle is 0.5ms the servo is supposed to moved to one end but instead, it seems to take a 45º position. For every other position, the servo also moves but it doesnt move accordingly to the duty cycle.
I have tested the servo with an arduino uno and works wonders.
What could be the problem?
Any ideas are welcomed.
1.Did you simulate your design?
2.What's the PWM frequency that you're trying to generate? I know that hobby grade servos work at around 400Hz - not 10KHz...
Thanks for the reply, I already found what the problem was. The frequencu divider has to de divided by 2 so instead of 5000, it has to be 2500 to get a frequency of 10KHz.
Also, 10Khz wont be the frequency to feed the servo, it will be the frequency to generate the pwm to feed the servo.
