Hi, colleagues!
I have found an error in Q5. It consists in wrong transmitting parameters from Verilog file to upper level.
For example, parameter hex_8_bit = 8'h7f;
Every time then you create a symbol from file, Quartus converts parameters into binary kind.
One exclusion is direct typing of the parameter in decimal kind. In this case conversion is always okay: dec_direct = 999;
The error occurs when parameter exeeds 7 bits.
Please, compare
parameter hex_7_bit = 7'h7f;
As you can see in the picture, the prefix B is absent, that causes the error.
I have attached QAR archive (zipped) in order to you could check this yourselves.
I believe, my info will help you to avoid problems in your designs. Be careful.
Regards,
YUV
