Series inductor for higher voltage rating
francis29
Member level 5
India
I need a inductor part that is rated for 1000Volts. Can I use two inductors ( rated for 500V and half the inductance of required value ) in series?
Yes, the voltage drop across each (identical) inductor should be 1/2 the total.
The tolerance of the inductance values will cause that voltage division to proportionally vary, of course.
what about stray capacitance, and ringing...
I´d not call it a safe solution.
Klaus
Once it is not clear the inductor tolerance you are about to use, and considering that you can achieve accurate values with resistors, I would think of adding high value equal resistors in parallel and "center tapped" with both inductors - likewise we often do with electrolitic capacitors in series - just to better ensure proper voltage balancing.
