Can post a diagram? Might be wrong connection? The flat portion of the LED is negative.
Well, tell me if im doing this right.
Thanks
Yup. It's correct.
The top 2 row and bottom 2 row is horizontal connected, for power supply or your battery purpose. The middle rows are those vertically connected. The other method you can try is wire wrap. Wrap wires to your components
why U r using battery for this indoor project! WHY CANT U USE a low amps step down transformer (230/9) for power supply so that u could connect it to 230 v ac.
For LEDs , Even u can connect those directly to 230v WITH A HIGH RESISTANCE AND DIODE IN SERIES WITH THE LED CHAIN.
THE RESISTANCE SHOULD BE DESIGNED CAREFULLY.
TO DESIGN THE RESISTOR,CONSIDER THE MAX SAFE CURRENT THROUGH LED.
ALSO,remember 230V AC is the RMS voltage, the peak voltage is around 325.
