The point is to take decission wheter to go with external serial to ethernet modules available in market or build it on our own.
I have allotted sufficient time to complete this task.
IT will be better if you try to use a prebuilt solution, I guess you will have to implement tcp ip if you want to do it on your own, it can be very time consuming
