serial receive byte count
praba_J
Member level 3
Member level 3
LINYI,CHINA
hi.. i am receiving continuous data from blood pressure module.. initially it will send 10 byte data and after some time it will send 6 bytes only.. when i receive 6 byte data i need to reduce receive buffer size to 6 from 10.. how can i do this...i tried with buffer count for every receive.. any suggestions??
i think your problem is that you do not know how much data is coming ? could be 10 or could be 6.
i do not know what protocol is being used, or even what system you are talking about, but maybe if you look at the the 1st byte received it will tell you (somehow) how many bytes are there in the packet. Then you can offload either 10 byes or 6 bytes from buffer
but if you reduce the buffer size to 6, then how will you receive 10 bytes if they come next ?
