kumarghz
Member level 5
- Joined
- Nov 25, 2006
- Messages
- 85
- Helped
- 10
- Reputation
- 20
- Reaction score
- 7
- Trophy points
- 1,288
- Location
- Penang, malaysia
- Activity points
- 1,938
serial pattern generator
Dear members,
I required to build serial pattern generator circuit for IC testing purpose using tester.
Currently I have built the circuit using TTL ICs. Below are the difficulties that I'm facing,
1. LTX Tester is not capable to generate serial pattern and the switching of tester is very slow, only 250us max can be archived, where my requirement is ~20ns switching.
2. TTL circuit has many weekness such as propagation delay ( each gate about 10ns)
3. I cant be modify the pattern in future if I use TTL circuits.
4. Lots of Under/overshots problem when use TTL.
I attached the sample of pattern. Please advice what would be the best approach in design of this Serial pattern generator?
regards,
Kumar
Dear members,
regards,
Kumar
