REIGN_
Newbie level 3
Is it possible to load data from a pin in a serial way and put it into an array in VHDL?
What i want to accomplish is for the data to be put through one pin and for each clock signal the data to be saved in a different cell of the array.
For example:
T1 -> Data_in : 10 to be put in Array(0,0)
T2 -> Data_in : 30 to be put in Array(0,1)
T3 -> Data_in : 25 to be put in Array(0,2)
So that in the end the array looks like this
Array {10, 30, 25}
The problem is that i want to use only one pin and not load the data parallel.
Thanks in advance
For example:
Array {10, 30, 25}
Thanks in advance
