SDM(ix)
Newbie
- Joined
- Feb 2, 2013
- Messages
- 4
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Location
- Iran
- Activity points
- 1,328
hi every one.
For a project, i need to use a serial memory like flash that have at least 2 megabytes for storing data. The problem i have is that i want to use the memory for regular data storing like every 1sec. I've seen a parameter in some serial flash chips is called number of write/erase cycles and it's about 100,000 times. if i understand correctly, if i rewrite data in memory for that times, the chip will damaged and don't work anymore! i want to use serial flash for storing data like a RAM. every time, i will write about 160 byte and every second. please help that which type of serial memory i have to use?
Thanks
Saeid
Thanks
Saeid
