serial communication with spartan 3
priteshkukadia
Newbie level 2
Newbie level 2
hello,
I want to make RS232 serial interface of fpga with pc. i need a vhdl code for this. also i want to know how to assign the pins in the fpga for this? I am using xillinx spartan 3 kit.
thank you.
hello,
thank you.
Hi priteshkukadia,
here is the sample reference code for serial communication with fpga.
What is your clock frequency? You can transfer data at different baud rate. I assume you supplied with 50 Mhz clock. Then you need to divide the clock to 9600 baud rate .
formula to calculate counter value.input frequency(50 MHz) / Baud Rate(9600) = counter value(5208)
In serial Communication, first you need to transfer start bit then transfer data bits and finally stop bit. For every bit transfer at the delay of counter value(5208).]
Fpga Interface, You need to use TX/RX pin from UART and also Clock pin.
Hope It help you.
Regards,
Shahul
