xilinx1001
Member level 3
- Joined
- Apr 3, 2013
- Messages
- 60
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Activity points
- 1,781
I need to measure the distance using range sensor. I need to trigger the sensor using nexys2 board.
The sensor is triggered by generating pulse from nexys2 board. Then the sensor generates the echo to measure the distance of the object.
When the object is detected the echo automatically becomes zero.
I am generating the trigger using the following code and it will automatically generates echo
How can I measure the distance using echo and how can I convert it to cm. The time period of each cycle is 20nsec. The distance is converted to cm using the following formula.
X in cm=(X in usec)/58;
How can I measure the distance in cm, the actual time period is in nano sec. I need to convert it by dividing by 1000 and then by 58 to convert it to cm.
How can I write the code for this. The symbol division(/) cannot be used in my current version of xilinx.
Regards
Vivek Alaparthi
code:
process(clk)
begin
if(clk'event and clk = '1') then
if(count <= "000000000001001011000" ) then
trg <= '1';
count <=count+"0000000000000000000001" ;
else
trg <= '0';
if (count ="1001100010010110100000") then
count<="0000000000000000000000";
end if;
end if;
end if;
end process;
Regards
Vivek Alaparthi
