amit251291
Member level 1
Hello Everyone,
I am doing one project. I have made one water level sensor which gives me output in current that varies from 0mA to 17mA approximately when watel level varies from 0 level to FULL level. Now after this i want to sense this level using 8051 and display this continuously varying water level on LCD.
So my idea was to convert this current output into voltage by I to V converter and then feed it to ADC to get digital values and then through 8051 it can be displayed on LCD. I checked voltages too (after I to V converter)& those were ranging between 2V to 5V (for above mentioned current) and with difference of approximately 0.02V.
So is this the correct way ?? Should i use current amp/voltage amp ??
or any other better way is there ??
