I want to install a security camara outside my house. but im not sure how to send the signal through my cable coax. what would be the most simple way of doing this without spending to much money?
Thanks!
Separating two almost identical signals is impossible. You have to have signals of different frequency to filter. It's all frequency or amplitude dependent, but you need frequency to separate. You can't separate amplitude.
In a simple setup, most of the security cameras send out baseband video and you will require a 75 ohms coaxial cable for each of the cameras to be connected to a monitoring TV or to a recording PC which can accept all of these video inputs. you can also add a modulator to each of the cameras using a different channel and pass this signal over one cable and at the monitoring location demodulate and separate each of the channels. Coaxial cagle RG59 is cheaper but with higher loss compared to RG11 for longer distances with lower loss but expensive.
you can use a "Video Modulators" and you can multiplex each video signals of each camera, netx you transmitter for the coax. In the receptor, you can demultiplex and the outoput connect to input of TV.
