Hello
i have a digital string that want to transfer in 4Km distance.i can't use wireless communication and should use wire to transfer.how can i send data with 500Kbit/second and without any repeater?
Dear baby_1
Hi
What wire ? can you use power line wire ? if yes , i offer you an old way , for this aim , it based on dispatching systems via power line . but for better guidance , more information needed .
Best Wishes
Goldsmith
Hello
Lets assume he does not have pwr line and dont want to use wifi or tcp/ip and dont want to use a simple cheap repeater... so what then ? and he did not answer my option about using tone burst say 1k for '0' logic 5k for '1' logic which later can be converted to logic level pulse .
Hello and Thanks
as dselec said i want to use QAM or QPSK modulation to transfer my data.could you introduce me some IC , circuit or reference that show me the theory and designing consideration about QAM and QPSK?
A phone DTMF tone is much too low a frequency to sent 500kbit/s data. The tone frequency would need to be sufficiently higher than 500kHz to give at least several cycles of the signal to detect the presence or absence of the tone.
Right i just set up ltspice with 1 Mhz carrier and it work fine .there is some more work on the filters and i am trying am and fm as well to see what is the best way.
next i will try freq shift and pass it into a long telephone cable i have and see how fast the decoder works , this project is interesting and i am taking personal interest in it..
Hello
