Hi Guys, I have an arduino UNO and have some sensors, I have made a database in mysql 000WEB.com, how can I send the data from sensors to the table's columns of thedatabase via GRPS connexion of M95 quectel?
Start by reading datasheets, write and test each functionality of the code in separate, and finally gather them step by step, checking what works as expected, what not. Simple like that.
Thanks for the reply, there're so many datasheet/catallogues of the Quectel M95 ( HTTP,TC/IP and so on), may I ask you which protocol I need to use for this data trasmission?
It's up on you choice, now you should define what protocol service is present or planned to run where database server is running, anyway for such a simple application like that on which just remote sensing is made, not properly remote control, perhaps a simple HTTP implementation pretty suffice, assuming the PC acting as a webserver.
