send and receive data to anthor pic16f84a
potetojb
Member level 3
Member level 3
Johor,Malaysia
Need Help
I write the serout and serin command to send data from PIC to another PIC
can anyone tell me, how to solve it, thank you
i am try many way to solve it , but still cant solve it
i am using PIC16F84A model try a simple code below
TX DATA
INCLUDE "modedefs.bas"
DEFINE OSC 4
loop:
IF PORTB.0=0 Then
GoSub led_on
Else
GoSub led_off
EndIF
GoTo loop
led_on:
SerOut PORTB.1,N2400,[$FF,$FF,"OK","A"]
Return
led_off:
SerOut PORTB.1,N2400,[$FF,$FF,"OK","B"]
Return
End
RX DATA
DEFINE OSC 4
dataon VAR BYTE
led1 VAR PORTB.1
led2 VAR PORTB.2
Loop:
SerIn PORTB.0,N2400,["OK"],dataon
IF dataon="A" Then led_on
IF dataon="B" Then led_off
GoTo Loop
led_on:
High led1
Low led2
GoTo Loop
led_off:
Low led1
High led2
GoTo Loop
End
after i on the supply and push the switch the led does not light
to see the led light on/off how could be???
really need a help
thank you
I use c so i'm not to up on basic, but I cant see where you configure the output lines data directions?
I suggest you to use PIC16f628 instead of 16f84.It has USART modul,it's much more easier to communicate.
ok coshkun..
can u give me some infomation about PIC16F628 and USART...
i am an amateur in PIC and PIC BASIC PRO
