Self learning IR transmitter
cebrax
Newbie level 6
Hey all,
I want to make a self learning infrared transceiver that learns every infrared code.
I know, it sounds like I want to step too many ladders.. But is possible right?
I am using Mikroelektronika mikroC PRO for PIC compiler.
Here is my code so far, but I am totally lost.
Any help?
bit infrared,buffer,change,j;
unsigned char measure=0,ref1=0,timepassed;
volatile unsigned char i=0;
void interrupt()
 if(INTCON.T0IF)
  measure++;
  TMR0=0;
  INTCON.T0IF=0;
void main(){
    unsigned char measuretxt[7];
    ANSEL = 0; // Configure AN pins as digital I/O
    ANSELH = 0;
    PORTB = 0;
    PORTC = 0;
    PORTD = 0;
    TRISB = 0;
    TRISC = 0;
    TRISD = 0x01;
    OPTION_REG=0x80;
    TMR0=0;
    INTCON.T0IE=1;
    INTCON.GIE=1;
    j=0;
    buffer=0;
    while(1)
     infrared=~PORTD.F0;
     if(buffer==infrared) change=0;
     else
      change=1;
      buffer=infrared;
     ____|     |____|     |____|     |____
     if(change)
      if(!j){ ref1=measure; j=1; }
      else{ timepassed=measure-ref1;
            ref1=measure;
      EEPROM_Write(0x00+i,timepassed);
      i++;
cebrax
Newbie level 6
anyone has a c code example?
linoko
Member level 2
Hi all,
What about self learning RF transmitter for car alarm?
cebrax
Newbie level 6
It works now, I will post the final code here after I re arrange everything.. Here is a prototype code:
bit infrared,buffer,j,change,writetoeeprom,devam;
unsigned char timepassed=0,eeprombuffer[80];
volatile unsigned char i=0,ii=0,k;
volatile unsigned int timer=0,offtimer=0;
void interrupt()
if(INTCON.T0IF)
 timer++;
 if(!change && i>5)
            {  offtimer++;
               if(offtimer>1000){ PORTC.F0=~PORTC.F0; writetoeeprom=1; offtimer=0;}
 TMR0=200;
 INTCON.T0IF=0;
void main(){
   //unsigned char measuretxt[7];
   ANSEL = 0;
   ANSELH = 0;
   PORTC = 0;
   PORTD = 0;
   TRISC = 0;
   TRISD = 0x03;
   OPTION_REG=0x88;
   TMR0=200;
   INTCON.T0IE=1;
   INTCON.GIE=1;
   j=0;
   //LCD_Init();
   buffer=~PORTD.F0;
   writetoeeprom=0;
   devam=1;
   while(devam)
    infrared=~PORTD.F0;
    if(buffer!=infrared)
     if(!j){ timer=0; j=1;}
     else
      timepassed=timer;
      timer=0;
      eeprombuffer[i]=timepassed; //EEPROM_Write(0x00+i,timepassed);
      i++;
     buffer=infrared;
     change=1;
    else
      change=0;
      if(writetoeeprom)
       PORTC.F1=~PORTC.F1;
       writetoeeprom=0;
       for(ii=0;ii<i;ii++)
        EEPROM_Write(0x00+ii,eeprombuffer[ii]);
       devam=0;
   while(1);
Fragrance
East Of Earth
sahu said:
Fragrance said:
hi
here you go it is based on pic16f84a
regards
Fragrance
can u it share asmably lang. & its fx. also
hi
I do not have any code for this only hex any way user cebrax has share his work thanks to him for his nice job he done, waiting for final version
Regards
Fragrance
cebrax
Newbie level 6
Re: [SOLVED]Self learning IR transmitter
Hello again!
I finished the receive and store part. But I can't replay. Any help?
bit infrared,buffer,j,change,writetoeeprom,devam,outputmode;
volatile unsigned char i=0,ii=0;
void receive(void);
void transmit(void);
void interrupt()
 if(INTCON.T0IF)
  timer++;
  TMR0=200;
  if(PORTD.F2)
   TMR0=0xFF - eeprombuffer[ii++];
   if(ii>=i) {INTCON.T0IE=0; outputmode=0; PORTC.F6=~PORTC.F6; }
   if(outputmode)
    PORTC.F5=~PORTC.F5;
    CCPR1L = 0x08;
    CCP1CON = 0x0C;
   else
    CCPR1L = 0;
    CCP1CON = 0;
   outputmode=~outputmode;
  else if(!change && i>5 && devam)
             {  offtimer++;
                if(offtimer>1000){ writetoeeprom=1; INTCON.T0IE=0;}
 INTCON.T0IF=0;
void main(){
    ANSEL = 0;
    ANSELH = 0;
    PORTA = 0;
    PORTC = 0;
    PORTD = 0;
    TRISC = 0;
    TRISD = 0b00000111;
    OPTION_REG=0x88;
    TMR0=200;
    INTCON.T0IE=1;
    INTCON.GIE=1;
   * PWM registers configuration
   * Fosc = 20000000 Hz
   * Fpwm = 37878.79 Hz (Requested : 38000 Hz)
   * Duty Cycle = 25 %
   * Resolution is 9 bits
   * Prescaler is 4
   * Ensure that your PWM pin (RC2) is configured as digital output
   * see more details on [url]https://www.micro-examples.com/[/url]
   * this source code is provided 'as is',
   * use it at your own risks
    PR2 = 0b00100000 ;
    T2CON = 0b00000101 ;
    CCPR1L = 0; //0x08 ; // 0b00001000;
    CCP1CON = 0; //0x0C ; // 0b00001100 ;
    j=0;
    //LCD_Init();
    buffer=~PORTD.F0;
    writetoeeprom=0;
    devam=1;
    outputmode=1;
    while(1)
     if(PORTD.F1) receive();
     if(PORTD.F2) transmit();
void transmit(void)
  if(!j)
    i=EEPROM_Read(0x80);
    for(ii=0;ii<i;ii++)
     eeprombuffer[ii]=EEPROM_Read(0x00+ii);
    j=1;
    ii=0;
    PORTC.F7=~PORTC.F7;
    INTCON.T0IE=1;
    TMR0=0;
void receive(void)
    while(devam)
     infrared=~PORTD.F0;
      else
       timepassed=timer;
       timer=0;
       i++;
      buffer=infrared;
      change=1;
     else
       change=0;
       if(writetoeeprom)
        PORTC.F4=~PORTC.F4;
        writetoeeprom=0;
        for(ii=0;ii<i;ii++)
        EEPROM_Write(0x80,i);
        devam=0;
        j=0;
Fragrance
East Of Earth
cebrax said:
Hello again!
Thanks for sharing what sort help required add a switch when it pressed system goes in learn mode and store noew code in internal eeprom,
regards
Fragrance
cebrax
Newbie level 6
I already did that I think.. Do you think this is the problem?
Fragrance
East Of Earth
if you only want to make the receiver then you required self learning switch to add please note that there universal remote transmiter in the market which well work with any system you can used this as test system.
tommorow will try to send you a universal receiver code written basic proton
regards
Fragrance
cebrax
Newbie level 6
I've completed the learning part, it can successfully store the delays(well, with some 10-20 usec error). Now replaying it is problem.. I don't have an oscilloscope that's why I can't see my output waveform. Can any one out there compile and look at the output?
Fragrance
East Of Earth
If you have proteus you can do it easly in side the proteus (used proteus scope to check signal) let me know which version you have i can guide you how and send you the model for this purpose
regards
Fragrance
cebrax
Newbie level 6
Thanks Fragrance, I will check it out!
cebrax
Newbie level 6
Hey all!
After a long delay, I wrote a new program. This one is not working real-time, I mean there is no multi-tasking and stuff... But this works!
I have tested for my TV (VESTEL) and VCR (YUMATU) and they work!
I use TFMS 5360 which is a receiver for 36kHz and I send 36 kHz modulated signals.. Maybe that's why I can't clone my airconditioner's remote...
Here it is! Any suggestion will be really cool
bit infrared,buffer,change,initial,sample,loop,output;
volatile unsigned int timer=0;
volatile unsigned char i=0,j=0,timetable[70];
void receive(void);
void interrupt()
 if(INTCON.T0IF)
  if(timer<65534)timer++;
  TMR0=50;
  //PORTC.F1=~PORTC.F1; // will change per 17.8 usec = 1 timer
  INTCON.T0IF=0;
void main()
    ANSEL = 0;
    ANSELH = 0;
    PORTA = 0;
    PORTC = 0;
    PORTD = 0;
    TRISC = 0;
    TRISD = 0b00000011;
    OPTION_REG=0x88;
    TMR0=50;
    PR2 = 0b00100000 ;
    CCPR1L = 0x00; // 0x0F ;
    CCP1CON = 0b00001100 ;
    INTCON.T0IE=1;
    INTCON.GIE=1;
    initial=1;
    sample=1;
    buffer=~PORTD.F0;
    delay_ms(5000);
    while(1)
      infrared=~PORTD.F0;
      if(buffer!=infrared){change=1;buffer=infrared;PORTC.F1=1;} else change=0;
      if(change && sample)
       if(initial)
        timer=0;
        initial=0;
       else
        timetable[i++]=timer;
        timer=0;
      if(!initial && timer>=2000 && i>2)
       for(j=0;j<=i;j++)
        EEPROM_Write(0x00+j,timetable[j]);
       PORTC.F0=1;
       while(1)
        while(PORTD.F1);
        j=0;
        for(j=0;j<=i;j++)
         timetable[j]=EEPROM_Read(0x00+j);
        loop=1;
        j=0;
        timer=0;
        CCPR1L = 0x0F;
        for(j=0;j<=i;j++)
         while(timer<timetable[j]);
         timer=0;
         output=~output;//CCPR1L = 0x0F;CCPR1L = 0x00;
         if(output)CCPR1L = 0x0F;
         else CCPR1L = 0x00;
        CCPR1L = 0x00;
        PORTC.F7=~PORTC.F7;
        delay_ms(255);
Nforcer
Newbie level 3
This is awesome! being new to microcontrollers, I was trying to figure out a way that I could convert the IR from up/down volume on my dish remote to send the learned IR sequence from my A/V receiver up/down volume which apparently the Dish Network remote doesn't have the codes for. Using your code, I think I'll be able to built a IR receiver/converter/repeater so that I can give my wife the pleasure of one less remote she has to get out.
