I am trying to work out a self driven 3 wire piezo...
The circuit is very easy and I have attached it below...
The resistor values are 10k and 180k with an inductance of 60mH, while the circuit should work fine at +5V supply and the frequency for piezo is 3KHz.
Even though having all the information correct(I have seen this circuit work in same condition with same values of everything), My circuit seems to have lost its way somewhere and I am not able to troubleshoot it.
Please can someone point out where I could be going wrong???
I am not sure if my inductor is doing good, how to I test its condition??
Also if i remove the inductor and connect GND instead to emitter, the buzzer beeps but at very low output...
Thanks...
This is what i am referring https://www.mouser.com/ds/2/40/piezo-43596.pdf this is the link of PDF
page number 8 is where i found this....could you please take a look and suggest
Thanks..
I asked for a working sample for the seller of piezo... And this is the circuit I was forwarded with a video clip of it working... I asked for the values also, hence I know the values for sure.
And yes the feedback goes to the base but through a resistor... Actually I want to squeeze out more output that is why I am using an trying to use with inductor...
Thanks..
The datasheet you found shows one schematic like the one you posted and two schematics like the ones I posted. Somebody does not know anything about a simple piezo beeper, the seller of your circuit or the circuits I found. Maybe your seller got the emitter and collector pins of the transistor reversed?
Why not buy a beeper that works properly from a local distributor (not ebay) and look inside it?
I believe that the oscillator topology can work under circumstances, but it may depend on additional parameters of the inductor like parallel capacitance, series resistance respectively loss factor, saturation current. Using the same "values" doesn't involve an identical inductor I presume.
You did not show a photo or the datasheet of the piezo beeper you have. The ones that are very loud are mounted in a resonant plastic case and the case is designed for the resonant frequency of the piezo.
I have one and it is powered from only 3V and it is loud. With a 9V battery it can be heard far away.
