kitepassion
Member level 3
- Joined
- Jan 5, 2010
- Messages
- 54
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,286
- Location
- US
- Activity points
- 1,659
Hi all,
I have a sensor with a configurable pin. It can be configured to have a voltage output or a current output. They are not the same in the sense that the current is not the translation of the voltage. So I want to clearly be able to measure both of them but without affecting their value. I do not want to affect the current measurement when measuring the voltage and vice-versa.
I need to use a level translator for the voltage reading.
Is the solution provided in the image good? Can you suggest me another solution?
Thank you!
Thank you!
